relationship advice?
Yep
What happened Matty?
Spoke to her last weekend, said I'm not gonna have any regrets, so just one last time, do you want to try again?
She said No. Had a bit of an argument, got upset, next day thought "f**k you" and started moving on. Today she messaged me about picking up her shit then wanted me to drop it off, I said No. Of course she started an argument over it and resorted to insults, and I didn't. I didn't give two f**k's, I felt nothing anymore, and I loved it.
Add in the fact that I'm seeing a f**kin cute as f**k chick this weekend, 10 times hotter than my ex... yeah, I'm already happy :P
Great to hear mate, it'll only get easier too. Sounds like you got closure from the "no regrets" thing, pushing all the blame onto her.You may have a relapse or two along the way (hopefully not), but stay strong - they will disappear in time and keeping yourself distracted is a great way about it. If you start thinking about her or get the urge to communicate again, just think about all the things that pissed you off about her and how she hurt you during the break up.
Don't fall into the trap of comparing new girls to your ex, as is common after a recent break up and can bring up feelings you don't want. Just have fun and enjoy the good parts of being single. You never know when you'll meet another one worth keeping!
And...it's completely normal to always have a soft spot for someone you once loved...when someone is a huge part of your life for so long, there will always be memories and nostalgia. So don't feel bad about that if it happens.
:cheers:
I'm like 178cm ~90kg and I wear a 52......
... I... I don't know brah. Didn't try 48 since 50 felt pretty damn snug... Could try when I go back but :O
edit: also probably not some ripped unit like you.... yet. (A LONG WAY AWAY "YET") :P
You might be alright mate. I'm snug in a 52 and 187cm, only 80kg. Body shapes and brands vary so much. Just make sure it's tight, but allows you to move around on a bike. Pas had me sit on a bike at Peter Stevens, which you should do to get a feel for if the gear is too restrictive. And remember, it will loosen up over time. You're doing the right thing :thumbsup:
Dezz has huge legs if I recall correctly.
Yep
fuck bitches
get money
Oooh, that's an idea. When I go to make my purchase I might ask if they'll let me do just that :D. Yeah with the loosening up considered, I was edging towards the 50. Also it had the insert liner thingy you could take out for summer, which frees it up a little? Plus my cut continues... maybe factor that in... xD.
Cheers for advice though, liking the sit-on-a-bike-there-with-it idea.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
