relationship advice?
Yep
What happened Matty?
Spoke to her last weekend, said I'm not gonna have any regrets, so just one last time, do you want to try again?
She said No. Had a bit of an argument, got upset, next day thought "f**k you" and started moving on. Today she messaged me about picking up her shit then wanted me to drop it off, I said No. Of course she started an argument over it and resorted to insults, and I didn't. I didn't give two f**k's, I felt nothing anymore, and I loved it.
Add in the fact that I'm seeing a f**kin cute as f**k chick this weekend, 10 times hotter than my ex... yeah, I'm already happy :P
Great to hear mate, it'll only get easier too. Sounds like you got closure from the "no regrets" thing, pushing all the blame onto her.You may have a relapse or two along the way (hopefully not), but stay strong - they will disappear in time and keeping yourself distracted is a great way about it. If you start thinking about her or get the urge to communicate again, just think about all the things that pissed you off about her and how she hurt you during the break up.
Don't fall into the trap of comparing new girls to your ex, as is common after a recent break up and can bring up feelings you don't want. Just have fun and enjoy the good parts of being single. You never know when you'll meet another one worth keeping!
And...it's completely normal to always have a soft spot for someone you once loved...when someone is a huge part of your life for so long, there will always be memories and nostalgia. So don't feel bad about that if it happens.
:cheers:
I'm like 178cm ~90kg and I wear a 52......
... I... I don't know brah. Didn't try 48 since 50 felt pretty damn snug... Could try when I go back but :O
edit: also probably not some ripped unit like you.... yet. (A LONG WAY AWAY "YET") :P
You might be alright mate. I'm snug in a 52 and 187cm, only 80kg. Body shapes and brands vary so much. Just make sure it's tight, but allows you to move around on a bike. Pas had me sit on a bike at Peter Stevens, which you should do to get a feel for if the gear is too restrictive. And remember, it will loosen up over time. You're doing the right thing :thumbsup:
Dezz has huge legs if I recall correctly.
Yep
fuck bitches
get money
Oooh, that's an idea. When I go to make my purchase I might ask if they'll let me do just that :D. Yeah with the loosening up considered, I was edging towards the 50. Also it had the insert liner thingy you could take out for summer, which frees it up a little? Plus my cut continues... maybe factor that in... xD.
Cheers for advice though, liking the sit-on-a-bike-there-with-it idea.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
