only made 285rwkw.. looks like lots of money (and time) spent for that lol pretty awesome tho
not really...
it's 285 on that wrecker motor which is temporary... it's just testing it.. he has another motor which it's all going onto and will be tuned more agressively...
trent is guessing mid 300's....
which i'm afraid son... in a 1300 odd kg VN / VP commo... will place your 370rwkw squarely in his rear view mirror :P
1300kg is still light for mid-300kws in my books lol.
that was my point
do you know much about how its setup? ie. supercharger covers mid-range and then turbo tops it off?
supercharger only for bottom end
turbo takes over when it hits full boost.
haven't seen the graph yet but it's hitting 20psi by 2600 revs so will be a crazy crazy motor
Get the slix..they look half decent when you're off the bike
I'll be getting a pair soon to replace the plain blue ones I got
Yup, think I will.
In other news, ACQUIRED BIKE LICENSE* !!
*Really it's still just a permit :P
Had a ball today though, good fun.
not really...
True, light car I wonder what sort of torque figures that thing puts out would need some fat rubber to keep it under control
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
