not really...
it's 285 on that wrecker motor which is temporary... it's just testing it.. he has another motor which it's all going onto and will be tuned more agressively...
trent is guessing mid 300's....
which i'm afraid son... in a 1300 odd kg VN / VP commo... will place your 370rwkw squarely in his rear view mirror :P
Nah he'll be right, Leigh's are roller dyno figures :P
Im not going to bite on the dyno comment... Although I will admit I do want to :P
I don't think you guys appreciate how much difference 400 kgs really is...
For an equal power to weight that car actually only needs 280rwkw to be on par with Leigh, and any more is gravy
If that car makes 350 we are talking approx 270 rwkw / tonne vs Leigh's 210 odd
That is stupid quick....
Although being a commo it probably has 400kg worth of subs :P
my car used to have 400kg worth of subs in the boot. i removed them and it made no difference to how the car feels.
on a side note, would you be interested in the guts for a 2.3 kit or a big ass turbo kit for your emo?
Nah, not building the evo....
Also, there is no way 400 kgs would not make a difference
lames.
know anyone that would be interested?.
my car has the worlds most retarded tune on it, you could be out dragged by a mobility scooter from a standing start. no guts at take off, flat spot at 2k, goes ok for a bit till 3k then flat spot agian, then takes off after 3k.
taking the subs out made no difference to how that series of events occured.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
