Im not going to bite on the dyno comment... Although I will admit I do want to :P
I don't think you guys appreciate how much difference 400 kgs really is...
For an equal power to weight that car actually only needs 280rwkw to be on par with Leigh, and any more is gravy
If that car makes 350 we are talking approx 270 rwkw / tonne vs Leigh's 210 odd
That is stupid quick....
Although being a commo it probably has 400kg worth of subs :P
still, why is it that 1390kg gtsts with 325rwkw can only pull 12s? :P
there's a lot more to it than just power to weight, gearbox / ratios, diff / ratios, torque, turbo lag, power curve, tyres - not saying it wouldn't be fast though just saying a lot more to it, there's a reason why my brothers light gtst can't get off the line for shit it's too darn light at the back and that thing kills my power to weight even in 2nd it spins as soon as it hits full boost with 275 nt05s lol
Hopefully I'll get deep into the 11s (anything around 11.5 I'd be stoked) at heathcote next month, will have to be careful off the line don't want to break my input shaft or tail shaft lol
Edited by UNR33L
Comes down to car setup clearly, in all cases, but that's an unknown quantity in this car... All we know is power and weight.
You realise this wouldn't have even been brought up if you weren't constantly dickbagging on about your cars power :P
Hahaha yea I know
Then you have overpowered bikes :P
can't get over how expensive seat mounts are... rails are pricey enough. charge $160 for an aluminium set and they don't even drill holes in them.
made my last set, doesn't take long with the right tools. need another set for passenger now, time to get some aluminium
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
