and it's not that I dont like anything not cooked by myself, it's more that grilld is half assed and fkn expensive.
i'm happy to eat that food... but a grilld burget is a $5 burger and no more
Guy who bought my evo.
Got the car checked at an Independant mechanic of his choice, who wrote up a list of small issues he found.
List was given directly to the buyer, wanted 3 of those points on the list fixed.
I got two items fixed by his mechanic and got Scott to do the last one.
Now he's complaining to me saying that there's a knocking sound.
Like you've bought the car now, everything u wanted to be fixed was fixed, why are u complaining now after you have transferred it?
It's 12 year old car with 125km on the clock. Of course there's going to be sounds, it's not brand new.
You need to do this
http://www.youtube.com/watch?v=lqqq-sU2SQo
rofl... evo's are full of noises
my brakes just started squealing, and i have a noisy lifter or a blown exhaust gasket since i changed the turbo setup. sounds similar to this youtube clip, except i have a loud squeal on boost
want to look at it this weekend, but have to clean the house/yard for an inspection.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
