Tried Vegie Bar today for lunch, was pretty decent for a full veterinarian place.
Macadamia salad was nice, the wraps were pretty good too. Only bad thing is Brunswick St, Fitzroy is full of god dam hipsters!
you sure you are eating at the right place?
I guess so? Was first time going to a veterinarian restaurant and was better than i thought, place was packed as too.
quoted for continuous lulz
Despite its original purpose as a back massager, the Hitachi receives more notable acclaim within the adult film and toy industries, where it is often heralded as the greatest vibrator of all time :thumbsup:
The more that you know!
hahaha didn't know that till you mentioned it! I wonder why they made a back massager shaped that way though, doesn't really make sense :blink:
Yes, and nothing related to Stoya or the hitachi art video.... :ph34r:
righhht :P
Edited by arcenite
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
