Anyone had a varex long term? Reliable?
Anyone got the optional rpm based controller?
yeh had one.. reliable? the muffler is, not the actual control box and remotes, i went through 2 boxes and remotes..
a few other people have said the same.
Me. No issues here; works like a charm. I usually leave it open though, occasionally switching it to silent and back now and then just to keep the mechanism from sticking.
Didn't know they had an RPM controller. I prolly wouldn't bother with that in a turbo car though; seems counteractive to spooling up.
All these avatar changes i cant keep up with who's who. :(
Few mates with varex exhausts, couple of problems here and there but nothing too major..
On another note, duno why I got so drunk last night and having to pick my mate up from airport this morning :(
at airport now. only here for emotional support and chauffeur. wouldn't mind so much if the mrs' mother wasn't here. would rather be seeing a musical theatre performance... oh wait, I have to do that tonight too.
:| kinda wish I was at work all day.
The emo has a decent sized muffler on it but at idle it is very deep and boomy, the idea being to just have it open above 3k
I can see how this works.
he says it's sold.
askes for your contact detaisla dn bank accoutn to give you the 200$..monies gone.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
