The problem is individuals owning a VW as far as those whom I know love to stick their noses in the air and associate it as a "prestige" and therefore better which is generally not the case. In addition to the tuning etc. made to the engine and thinking that they have superior performance/reliability as opposed to japanese cars, assuming that you're not trashing the shit out of your jap car.
Regarding the leaning out thing, it's because they made it readily available and marketed it and made it mainstream, people don't realise the harm they are doing to their cars and take them to a VW service centre which are probably going to use sub-par oils/fluids that are not made for the increase in power obtained from the aggressive tune, not to forget, stock internals.
Anything above 227 hp (not much room to play with) from a stock GTI engine is going to cause problems, APR stage 1 gets you 254 hp, way above the limit for the stock engine. The Audi TTS which has 265 hp has the same 2.0L I4 engine reinforced from factory, if the engineers from Audi thinks that a reinforced engine is required to take that sort of horsepower, what makes you think that APR's claims that they are tuning it within the limits of a stock GTI engine without any reinforcements are true? Furthermore, every 2.0L i4 engine from VW that produces more or equal to 169kw's of power comes with reinforcements made to the internals. I think their engineers know what's good for their own engines and what isn't.
4th paragraph from: http://www.caranddriver.com/reviews/2010-audi-tts-road-test-review highlights the reinforcement of the engine internals from the 2.0L i4 engine to accommodate the increase in power from the tune/turbo upgrade.
But meh, at the end of the day, I just hate it when people judge you for driving a japanese car when they drive a european one. It's not the car, just the driver's that reek of elitism that annoys me :P , and my advice to any potential/current GTI owners, please just keep the engine stock or face reliability issues down the road, unless you're going to reinforce the internals :thumbsup: then go crazy!! :banana:
Edit:
Yes it is xD polo's too are pretty affordable hatches too nowadays (plus it's european :rofl2:) , good for transporting stuff around :yes:
Seriously cbf responding to any of that. Im not here to argue. A lot of work went into that post ;)
the issue is never the HP, its the torque.
limiting torque during the lower/mid rpm band and then increasing it in the upper rev band can do wonders for keeping a not so tough bottom end alive while still giving you a look at me hp figure.
Don't tune your GTI and don't be like one of them snobbish GTI owners :P but it's a cute little hatch no doubt. Buuut meh.. it's a girls car imo, but that's just me! :laugh:
Anything above 169kw and 300nm then :woot:
Edit:
VW's are probably not shit, but their owners are making them shit. And their owners that are making them shit are retarded.
Edited by arcenite
crapping out at a mere 300nm is fairly pez. tbh, thats not a lot of safety fat left in it by VW, again its engineered to do the job and not much beyond.
which is likely the same issue they are running into with the DSG boxes, yes they work, but if its engineered with the same slim margins any increase or abuse/hard usage starts having a big impact on how long it will last.
I drive a vw jetta, I've never thought of it as a prestige car...just don't get that feeling, especially because it's a fwd tractor and the interior is so plain imo. :/ if i had the choice i'd take my 34 back in an instant.
Honda is best.
Sadly the s2000 was shunned and people would rather be seen in a z4 :ermm:
Yeah those dsg boxes are a no-no if you're going to drive it hard, they wear out pretty quickly, then you'll have to deal with the cost of european parts... :unsure:
Edit: I hate it when people say, "It's just a Honda" when they refer to the s2000 :rant: when comparing it to the z4.
Edited by arcenite
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
