The problem is individuals owning a VW as far as those whom I know love to stick their noses in the air and associate it as a "prestige" and therefore better which is generally not the case. In addition to the tuning etc. made to the engine and thinking that they have superior performance/reliability as opposed to japanese cars, assuming that you're not trashing the shit out of your jap car.
Regarding the leaning out thing, it's because they made it readily available and marketed it and made it mainstream, people don't realise the harm they are doing to their cars and take them to a VW service centre which are probably going to use sub-par oils/fluids that are not made for the increase in power obtained from the aggressive tune, not to forget, stock internals.
Anything above 227 hp (not much room to play with) from a stock GTI engine is going to cause problems, APR stage 1 gets you 254 hp, way above the limit for the stock engine. The Audi TTS which has 265 hp has the same 2.0L I4 engine reinforced from factory, if the engineers from Audi thinks that a reinforced engine is required to take that sort of horsepower, what makes you think that APR's claims that they are tuning it within the limits of a stock GTI engine without any reinforcements are true? Furthermore, every 2.0L i4 engine from VW that produces more or equal to 169kw's of power comes with reinforcements made to the internals. I think their engineers know what's good for their own engines and what isn't.
4th paragraph from: http://www.caranddriver.com/reviews/2010-audi-tts-road-test-review highlights the reinforcement of the engine internals from the 2.0L i4 engine to accommodate the increase in power from the tune/turbo upgrade.
But meh, at the end of the day, I just hate it when people judge you for driving a japanese car when they drive a european one. It's not the car, just the driver's that reek of elitism that annoys me :P , and my advice to any potential/current GTI owners, please just keep the engine stock or face reliability issues down the road, unless you're going to reinforce the internals :thumbsup: then go crazy!! :banana:
Edit:
Yes it is xD polo's too are pretty affordable hatches too nowadays (plus it's european :rofl2:) , good for transporting stuff around :yes:
Seriously cbf responding to any of that. Im not here to argue. A lot of work went into that post ;)
the issue is never the HP, its the torque.
limiting torque during the lower/mid rpm band and then increasing it in the upper rev band can do wonders for keeping a not so tough bottom end alive while still giving you a look at me hp figure.
Don't tune your GTI and don't be like one of them snobbish GTI owners :P but it's a cute little hatch no doubt. Buuut meh.. it's a girls car imo, but that's just me! :laugh:
Anything above 169kw and 300nm then :woot:
Edit:
VW's are probably not shit, but their owners are making them shit. And their owners that are making them shit are retarded.
Edited by arcenite
crapping out at a mere 300nm is fairly pez. tbh, thats not a lot of safety fat left in it by VW, again its engineered to do the job and not much beyond.
which is likely the same issue they are running into with the DSG boxes, yes they work, but if its engineered with the same slim margins any increase or abuse/hard usage starts having a big impact on how long it will last.
I drive a vw jetta, I've never thought of it as a prestige car...just don't get that feeling, especially because it's a fwd tractor and the interior is so plain imo. :/ if i had the choice i'd take my 34 back in an instant.
Honda is best.
Sadly the s2000 was shunned and people would rather be seen in a z4 :ermm:
Yeah those dsg boxes are a no-no if you're going to drive it hard, they wear out pretty quickly, then you'll have to deal with the cost of european parts... :unsure:
Edit: I hate it when people say, "It's just a Honda" when they refer to the s2000 :rant: when comparing it to the z4.
Edited by arcenite
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
