The problem is individuals owning a VW as far as those whom I know love to stick their noses in the air and associate it as a "prestige" and therefore better which is generally not the case. In addition to the tuning etc. made to the engine and thinking that they have superior performance/reliability as opposed to japanese cars, assuming that you're not trashing the shit out of your jap car.
Regarding the leaning out thing, it's because they made it readily available and marketed it and made it mainstream, people don't realise the harm they are doing to their cars and take them to a VW service centre which are probably going to use sub-par oils/fluids that are not made for the increase in power obtained from the aggressive tune, not to forget, stock internals.
Anything above 227 hp (not much room to play with) from a stock GTI engine is going to cause problems, APR stage 1 gets you 254 hp, way above the limit for the stock engine. The Audi TTS which has 265 hp has the same 2.0L I4 engine reinforced from factory, if the engineers from Audi thinks that a reinforced engine is required to take that sort of horsepower, what makes you think that APR's claims that they are tuning it within the limits of a stock GTI engine without any reinforcements are true? Furthermore, every 2.0L i4 engine from VW that produces more or equal to 169kw's of power comes with reinforcements made to the internals. I think their engineers know what's good for their own engines and what isn't.
4th paragraph from: http://www.caranddriver.com/reviews/2010-audi-tts-road-test-review highlights the reinforcement of the engine internals from the 2.0L i4 engine to accommodate the increase in power from the tune/turbo upgrade.
But meh, at the end of the day, I just hate it when people judge you for driving a japanese car when they drive a european one. It's not the car, just the driver's that reek of elitism that annoys me :P , and my advice to any potential/current GTI owners, please just keep the engine stock or face reliability issues down the road, unless you're going to reinforce the internals :thumbsup: then go crazy!! :banana:
Edit:
Yes it is xD polo's too are pretty affordable hatches too nowadays (plus it's european :rofl2:) , good for transporting stuff around :yes:
Seriously cbf responding to any of that. Im not here to argue. A lot of work went into that post ;)
the issue is never the HP, its the torque.
limiting torque during the lower/mid rpm band and then increasing it in the upper rev band can do wonders for keeping a not so tough bottom end alive while still giving you a look at me hp figure.
Don't tune your GTI and don't be like one of them snobbish GTI owners :P but it's a cute little hatch no doubt. Buuut meh.. it's a girls car imo, but that's just me! :laugh:
Anything above 169kw and 300nm then :woot:
Edit:
VW's are probably not shit, but their owners are making them shit. And their owners that are making them shit are retarded.
Edited by arcenite
crapping out at a mere 300nm is fairly pez. tbh, thats not a lot of safety fat left in it by VW, again its engineered to do the job and not much beyond.
which is likely the same issue they are running into with the DSG boxes, yes they work, but if its engineered with the same slim margins any increase or abuse/hard usage starts having a big impact on how long it will last.
I drive a vw jetta, I've never thought of it as a prestige car...just don't get that feeling, especially because it's a fwd tractor and the interior is so plain imo. :/ if i had the choice i'd take my 34 back in an instant.
Honda is best.
Sadly the s2000 was shunned and people would rather be seen in a z4 :ermm:
Yeah those dsg boxes are a no-no if you're going to drive it hard, they wear out pretty quickly, then you'll have to deal with the cost of european parts... :unsure:
Edit: I hate it when people say, "It's just a Honda" when they refer to the s2000 :rant: when comparing it to the z4.
Edited by arcenite
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
