Yeah was baycorp I think...didn't pay a cent of interest..Cant complain..
exactly... you did well considering what could have happened
also you provided a perfect case study to show the system works :P
i wouldn't bother with the split dump, not worth it at such low power levels, by the time you need it you have an external gate anyway.
i picked up a dump, front and cat for $300, tomei dump, trust front and nfi what cat it was.
those aftermarket turbos expect even 2nd hand to have to pay, my ef3 2nd hand was still $1600
Hmmm, yeah. That's why I was thinking wasn't on my immediate to-do list. Haha yeah some good second hand parts would be nice!
Haha yeah. Should probably include MAP2.5 to that list. I think I'd be happy with a 9 turbs however, dat response.
The other funds sink is the minor other supporting mods like bov, gauges... Maintenance stuff.
Aaaand of course sussy and wheels, and an e9 rear bar. Also I'm thinking nose chop.
So many plans xD
oh yeah and re evo... probably e7 best BFYB imho... 230awkw from just I/C piping, 8MR OEM turbo, fuel pump, full exhaust, boost solenoid and stock ECU flash.
I have most stuff... just need the turbo and LICP and i'm ready to go, so far have spent about $500 (secondhand stuff)
Yeah. Some 7s sold for some good prices. But I'd probably aim for a bit more, hence an 8. Not to mention other little nice things... like bigger fuel tank :P
3xe or whatever they're called do the licp for under $100 I think, with all the joiners and clamps too.
Brand new was cheaper than any other second hand I could find.
Yeah? Last I checked hot side around $150, cold side around $280... But as a set I think he does < $400 for both. But yeah like I said, x3e was what I was looking at for this :thumbsup:
What's wrong with the e7 tank... It makes you feel like the car's fuel efficient cos it only costs $50 to fill :P
see it's just not worth the hastle...
e85 will get me to what, 250awkw vs 230?
and for that I need to do injectors and make huge efforts for fuel
that's a lot of effort for less than 15kw/tonne
I feel it'd push more than 250, if pushing 230 w/ 98, though...
it's worth getting the tune etc... but TBH I ended up running the 33 on 98 most of the time due to CBFness
290rwkw is enough for daily duties in a gtst
Yeah I fear the ceebs will flow through me lol
Like buying an fc hako etc etc
from discussions on evo oz it seems to net around 250 w e8MR turbo and 260 w e9 turbo
hmm, what sort of boost is that running?
there's a caltex with e85 on my way to uni, so i think i'll be sweet! also more or less on the way to work (sliiiight detour). only drainer is if i need to go in the other direction haha... although dat dual map tune for worst case scenario...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
