Nice, Leigh! We go for a ride soon! I'll follow 100km behind dw :(
Also looks like my left headlight has karked it. Sigh. It's cold and dark cbf checking it now, but anyone know what it could possibly be? Just a replacement job? Factory xenons.
Also looks like my left headlight has marked it. Sigh. It's cold and dark cbf checking it now, but anyone know what it could possibly be? Just a replacement job? Factory xenons.
Don't worry my bike would be back there to - after I unstick the clutch... again
Who is good with sourcing oem nissan gear? My hicas ball joints are flogged
Outer Ball joint
http://amayama.com/search/?q=55154-0P800
Seal
http://amayama.com/search/?q=00922-13000
Tie Rod end(Though you shouldn't need this)
http://amayama.com/search/?q=55725-0C800
Tie rod
http://amayama.com/search/?q=48521-79T00
/start rant/
stupid sunday early morning drivers, can't fkn do hook turn properly in the city, took out my rear left quater and didnt even bother to stop. lucky it was outside the magistrate on williams/la trobe hopefully theresa some clear footage.
/end rant/
Thanks mang. Will fit 33 gtst?
Pretty sure I won't need the tie rods / ends
/start rant/
/end rant/
goodluck getting footage. they wont give it to you
Those are the gtst part numbers fresh outta fast. If your outer ball joints are darker your tie rod ball joints probably have a fair bit of play in them as well.
Ah, I didn't know they had rubber inside. I'll have a better look
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
