very clever.........
no idea tbh. im actually selling my skyline as i join sau...
but once the clubby is ready and i have all the cams gear for the car then ill look! might have a go at the hill climb at nats, other than that havent got a clue! i want something cheap and easy for my first time in the hsv. shes a big girl.
All you need is a cams approved helmet, fire extinguisher and some stickers and off away you go!
As for tracks, IMO Winton is easier for the beginner but Sandown is convenient because its so close
calder in a couple months as well, and this is a pretty good beginner track.
yea not a fan of concrete lol.
wont be going to hard as its my daily hahah! well i have a couple of helmets in the garage, hopefully one of them will work.
have a fire extinguisher in the boot, but yea need to have a bracket knocked up to bolt one to my pasenger seat...
have a magnetic battery sticker, just need one for tow....
would love to do a driver dynamics day as a refresher, but cannot justify 300 at the mo!
Never been to calder park
Is it mostly grass for run offs or concrete walls?
main straigh has plenty run off as it the drag straight, well was last time I was there.
rest is grass then concrete but it all straight line braking. it's really a very simple track.
shit condition tho thanks to 0$ spent on it and drifters.
You'll be fine
My first track day was Sandown in the wet in the daily R34
Just take it easy and you'll be fine!
So i see
Count me in then!
Stolen from his FB
But SAU VIC member Chris Madden has been driving this around.
1016655_10151453840572050_1308600656_n.j
Hnnng. The only thing tempting me to f**k responsibility and blow cash.
/will wait for labour to unf**k FBT so I can salary sacrifice that bad boy.
Must....resist....purchase
seriously tho aaron, you can have my 33 for 4350!
reg till nov! :woot:
ill even help you drop a manual in if you dont like the worked auto.
Lol the only boat I would buy is one that floats on water
Bit of press on the FBT changes
Im curious as to know your understanding and explanation on how and why this effects you?
Just trying to gauge the understanding of the changes from the public's point of view
Aaron you should pay attention as this change will effect you
Along with everyone else on your team that gets company cars!
Company pays FBT, and technically we are paying for the car as its apart of our salary and not as a benefit. Ie I can choose to be paid more and not be given a car..
My understanding is that tax is paid on default 20% private use for a salary sacrificed car.
The changes would mean I need to calc the private:business use; when salary sacrificing car I'm not using it for business but 100% private.
That's my understanding of it.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
