disappointed that he missed the pun in the first place...
gawd, you pay for it, but UPS delivery so quick, eastbay purchase should be here tomorrow. have a feeling it'll be when i'm not at home, though :'(
lmao ric
nah i want to use it for winton as well, so proper helmet.
mate with stock novtec no swaybars drums got 47 on rsr's + coils.
I think i can crack 45-46 as is with bigsways/bigbrakes/ stiffer coils
Will be fun, so where to look for helmets, bike stores?
westcoast4lyf
mate if you bring it back because you tried to assemble it but ended up f**king it up... i'm gonna tell you to gtfo xD
Nah I'm almost done. Couple of f**k ups by ikea I had to fix though, like oversized pre drilled holes..
It's just time consuming. I saw your car.. Was gonna box it in with trolleys.. Maybe next time
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
