Sigh... LPG for a power upgrade, not economy
It has a massive RON and I want to run dedicated for 240-250 rwkw, not some shitty duel fuel system.
Not to mention it will be cheaper to run and should be cop hassle free if set up correctly
Any reason for LPG over jumping on E85 bandwagon, convenience I'm guessing?
Does it also have the benefit of keeping your engine cooler like E85 does compared to 98?
From memory, it runs hotter unless it's PROPERLY setup, could be wrong though I looked into it ages ago so my memory is hazy on that.
Yum cha setups are for economy/tightarses and installer tune accordingly.
Thought about it but e85 economy sucks and evo fuel tank is the size of a coke bottle. LPG economy is the same but available everywhere.
It is also legit when you need to explain it to cops.
With intank walbro, 8MR turbo and BOV, highflow panel filter in stock box making LICP the only intake mod and a 3" exhaust with a varex this should leave me just shy of 250rwkw and relatively cop acceptable.
E85 leaves aftermarket stuff visible like injectors without the excuse of it being a non performance, legal LPG conversion and for some reason seems to be killing e7 4G63's
You're planning on dual fuel setup or straight gas?
Totally understand the convenience thing, especially evo tank aren't that big.
May have to run tanks in the boot, couple small ones on each side
Isn't straight gas legally unable to be epa'd, well that's what I heard whether it's true or not
But yeah can't run dual fuel and make power, needs to be straight gas to make more power than petrol
My accountant f**ked me
$7 refund
Anger rising
I've got a $33 due to the ATO :(
What is this? I don't even...
ATO must be crackin down. I claimed a lot and got back less than expected. oh well.
ATO = faggots
Hope you guys aren't being serious
Just because you lodge a tax return doesn't mean your automatically entitled to a refund
For your average John Doe your refund is more dependant on your employer rather than the Tax Office or Accountant
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
