Just drove my mates C63 AMG - never driven anything like it. Mental fast.
Hang round here a while, we have many, many quicker cars you can ride in :P
C63 runs what, mid 12's @ ~115 mph with an auto box?
Having said that, would definitely own a 63 for daily if I had the cash
Mid 12's but torquey as hell, just wouldn't keep traction. To me it felt quicker than the R35 I went in (as a passenger that time).
And anyone with a quicker car is welcome to take me for a drive :woot:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
