return flow coolers can support 300
the turbo could be getting choked though if it's in a stock housing... Ric's, old hypergear did this before he replaced it with a garrett... i'd have a good look at this
could also be your china wheels or massive gayness
Wouldn't buy any car from Tassie after knowing what panelshops would do and send down there and the dealers would sell
Going through it now with Maggie, so far no issues. However it's a long drawn out process now, about 3 years
@Plattsy
Mate of mine is going through a super hard time for his PR currently and he is from the UK as well
yea its shocking isnt it!
made a point of speaking to my non australian immigration officer (!) that i was guaranteed acceptance on a last remaining relative visa, and simply chose the partner visa because it was cheaper.
tis dog shite.
Seems my engine has a restriction!
Making 260rwkw on E85, only 8rwkw up from my 98 result...albeit with good gains down low and in the midrange. So something is choking it up top. RP and I suspect it may be the cat converter, so tomorrow it's getting made more "functional" and then retuned.
Could also be return flow cooler. Could also be turbo too small. Could be any of the things that make my car look as stock and legal as possible. Not fussed about top end; I switched to ethanol for the awesome mid range, but would be good to walk away from the exercise with a few more ponies up top if we can sort out the restriction.
What sort of return flow setup you got?
They could of just dropped the exhaust and test if they had time
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
