She looked a lot like Isla Fisher...
Current gf looks like Bonnie McKee.
:D
I had to google who Bonnie Mckee was lol
Yeah I would of played mind games, say hi & try convince for a catch up at some point make them leave thinking wtf?
I wouldn't waste my time saying Hi to my ex, but thats just me
Depends on the terms you parted on
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
