No-one would stock it, as they would have only ever sold one... To you...
I can make you anything. ;)[/quote
Hey scotty i remember reading a while back you could make pod enclosures / airbox still doing custom work? If so send me a pm
I do, but why bother with a pod enclosure? I saw a stock GTR airbox flowing 500kw the other day, the GTST one can't be far off as it uses the same panel filter...
Trent said my r32 gtst airbox was restricting above 230kw :(
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
