greedy car companies want to operate on a profit. how dare they.
and the government wants to encourage local sales and bail out aus made cars owned by billion dollar international companies. and then get their fingers wet getting 33% tax on vehicles valued over $60-something.
good one straya
Winton first time today. Off the top of my head.
Session 1: 2:03 - didnt know what I was doing
Session 2: 2:00.7 - slowly learning
Session 3: 2:00.9 - did same as last session. Didnt know what to do to go faster
Session 4: 1:57 - newbish friend helping me out with a few things I was doing wrong
Session 5: 1:55.5 - more experienced friend showing me lines for sweeper and s turn
Session 6: 1:53 - missus as passenger. Improving on what my friend pointed out with lines and braking
Not bad for sub 50 odd kw on re002 for first time. It has more in it as is. But no more track time. Will be back next time to improve! As is I think I can get 1:51-1:52 comfortably
Mate with same set up but with k24 e85 160fwkw was dipping into 1:42. Wtb mo powarh
  • Like 2
Nick, Hamish + Aaron: Thoughts on owning an Evo as a daily / weekend warrior?
Thinking about going and test driving a couple of Evo 8s.
Evo 8 would be a nice daily, just remember if you go a jdm 8 check for rust underneath
Well it's either that or start considering 7s and get a nice dirt bike or something for some weekend fun. Heard them rodz aint so great though. How much power was yours pushing out Nick?
235awkw and don't want to push too much more, some people have but depends for how long
It's the torque that kills them and because they get on the power so quick they tend to die if they push big power on stock rods
its fine, not the best on fuel similar economy to a skyline, just be mindful of the less than huge tank for daily duties if you do a fair number of KM/week.
as for the power thing, mines making 250 on 98 seems to be going fine so far.
If you're planning on modding it heaps go 8. I prefer 7 though, cheaper, I like the kit, and wasn't planning on modding it much at all.
Definitely recommend as a daily (if u don't mind regular fuel trips because if tank size) or weekender.
But after driving Scotty's Stagea last night, I seriously miss my old one.... Much more than the evo
need to rack up some kms on the pulsar this month. monthly meet at Alvin's work?
Come reefton spurs cruise next week brah. :)
I still have a reaction video of me and two mates from when Scotty took us for a spin in it, bloody epic. :D
Last night my mates were getting out of the lancer and they were just like "so much better than your 34"
Dat four door lyf coming in handy (although as a driver, no f**ks usually given anyway)
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
