Krysissyiuiuiuiuiuiuuiuiu came on a cruise one day after vu painted his car "bag of dicks orange" and we ended up out in the hills on an unsealed road with rocks and dust eeeeeervywhere...
peeps lolled
  • Like 1
Quite distracting ads on the SAU app, nothx.
Got Tapatalk to try, but can't find SAU... halp?
Skylines Australia or SAU was enough for me to find it.
go away rain... enough mud already
