Ishan next Friday we'll go for a ride with Leigh. Buy a scala G9 headset too.
Will look into said headset. Day time ride hopefully? Not that there's anything ominous about Friday the 13th...
Toby that is freaking hawt! On mobile though so can't see too clearly - is it black? If so, I do wish you the best in keeping it as sexy as it is bahaha.
Agreed on Doncaster Westfield parking. I usually only head there for movies... the grid up there is a nightmare. Scraped UNDER my car oh the feels... didn't make that mistake again thereafter LOL
Install HID kit.
Break HID kit
try to fix HID kit ( fail )
Break tacho
I dont even know how, but my tacho, fuel gauge, trip meter, temp all stopped working. And also my battery volt gauge and oil temp stopped.
With that said, does anyone have a link to the fuse layout in the cabin ?
Install HID kit.
Break HID kit
Break tacho
usually on the inside of the fuse box!
else
http://www.skylinesaustralia.com/forums/topic/331248-r34-gtr-fusebox-translation/
exactly the same as me! I scraped under my car today on the stupid metal 'speed humps' they have wasn't too happy about that.. also if you ever have to drive up all the levels inside the carpark.. those sharp corners where people pull out and you have to magically shrink your car to make it around the corner.. paranoid ill gutter rash a wheel..
Its japanese :( also deadlink, ive found something on google, but im not 100% on whether its for my car or not.
i bought an english sticker for mine - didnt put it on and dunno where it is tho :(
When did they put them in? Been ages since I last went in that place (left there feb this year).
Wanna swap cars? Mines high enough I'd imagine.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
