Ishan next Friday we'll go for a ride with Leigh. Buy a scala G9 headset too.
Will look into said headset. Day time ride hopefully? Not that there's anything ominous about Friday the 13th...
Toby that is freaking hawt! On mobile though so can't see too clearly - is it black? If so, I do wish you the best in keeping it as sexy as it is bahaha.
Agreed on Doncaster Westfield parking. I usually only head there for movies... the grid up there is a nightmare. Scraped UNDER my car oh the feels... didn't make that mistake again thereafter LOL
Install HID kit.
Break HID kit
try to fix HID kit ( fail )
Break tacho
I dont even know how, but my tacho, fuel gauge, trip meter, temp all stopped working. And also my battery volt gauge and oil temp stopped.
With that said, does anyone have a link to the fuse layout in the cabin ?
Install HID kit.
Break HID kit
Break tacho
usually on the inside of the fuse box!
else
http://www.skylinesaustralia.com/forums/topic/331248-r34-gtr-fusebox-translation/
exactly the same as me! I scraped under my car today on the stupid metal 'speed humps' they have wasn't too happy about that.. also if you ever have to drive up all the levels inside the carpark.. those sharp corners where people pull out and you have to magically shrink your car to make it around the corner.. paranoid ill gutter rash a wheel..
Its japanese :( also deadlink, ive found something on google, but im not 100% on whether its for my car or not.
i bought an english sticker for mine - didnt put it on and dunno where it is tho :(
When did they put them in? Been ages since I last went in that place (left there feb this year).
Wanna swap cars? Mines high enough I'd imagine.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
