Ishan next Friday we'll go for a ride with Leigh. Buy a scala G9 headset too.
Will look into said headset. Day time ride hopefully? Not that there's anything ominous about Friday the 13th...
Toby that is freaking hawt! On mobile though so can't see too clearly - is it black? If so, I do wish you the best in keeping it as sexy as it is bahaha.
Agreed on Doncaster Westfield parking. I usually only head there for movies... the grid up there is a nightmare. Scraped UNDER my car oh the feels... didn't make that mistake again thereafter LOL
Install HID kit.
Break HID kit
try to fix HID kit ( fail )
Break tacho
I dont even know how, but my tacho, fuel gauge, trip meter, temp all stopped working. And also my battery volt gauge and oil temp stopped.
With that said, does anyone have a link to the fuse layout in the cabin ?
Install HID kit.
Break HID kit
Break tacho
usually on the inside of the fuse box!
else
http://www.skylinesaustralia.com/forums/topic/331248-r34-gtr-fusebox-translation/
exactly the same as me! I scraped under my car today on the stupid metal 'speed humps' they have wasn't too happy about that.. also if you ever have to drive up all the levels inside the carpark.. those sharp corners where people pull out and you have to magically shrink your car to make it around the corner.. paranoid ill gutter rash a wheel..
Its japanese :( also deadlink, ive found something on google, but im not 100% on whether its for my car or not.
i bought an english sticker for mine - didnt put it on and dunno where it is tho :(
When did they put them in? Been ages since I last went in that place (left there feb this year).
Wanna swap cars? Mines high enough I'd imagine.
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
