You know where the cool restaurants are at home, though. Food is subjective...I've loved all the places we've eaten at...cept maybe one. Most of the world eats meat; I doubt catering to everyone's taste is even a criterion in earning a chefs hat. Hell I don't like some of the food served at some very reputable places and wouldn't even eat it but I wouldn't say the place is shit when I haven't / can't even eat the mainstay of their food/menu that they are famous for.
So go home...
Yeh amg c63 under a ton is do able but it'll have high kms
The a45 is awesome don't judge it from outside the interior is better then the c63!
I know of heaps of people with audi trouble man
There's no way in hell I'm spending $80k on a car I don't like the exterior of...
lol bikes exacerbate them. Do deadlifts; strengthen back; ride without ever getting a sore back. What'd ya do to it anyway?
No idea, ongoing problem. Have tried several strengthening things, deadlifts, medx (fancy back machine). Comes and goes. Scans show a couple of bulging discs then sometimes pinch on nerves
If they are some of the best restaurants in the world then they will cater for everyone.
One of the best things about owning/running one of the best restaurants in the world is that you don't actually have to cater for annoying-ass vegetarians or stupid requests
Will they do me a well done eye :P
Actually ate at Ash's Squires Loft lastnight...food was very good. CAAB angus porterhouse was very tasty and a good size (400gm) for the money. And shock horror I had it done medium :O
I asked for "medium rare" eye fillet the other day and seemed to come out pretty well done :\ didn't really bother me as it was a company expense but still! should of said rare!
Edited by UNR33L
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
