yeh... prolly ex demo to save some coin
leaning towards the 2.5l 2wd mazda cx5 maxx... recon i can get that at 30... but the hyundai is a strong competitor
i dunno alot about the cx5 id have though the hyundai is a larger car and probably higher spec'd for the coin.
a bloke at work has the kia sorrento i think it is? all leather and shiz deisel paid about 40k brand new hard to argue the value 5 year warranty and road side assistance.. makes you wonder why we pay so much for euros.. that generally fark up.
side note.. housing bubble thread so silent these days.. this disappoints me.
Why are half their insides on the outside?
I wondered about that as well, and yeah think it just to make them look fancy and shit on the plate.
plus are a smallish burger so they gotta do something to make it look like more food
Forgave them after the taste tho.
