yeh... prolly ex demo to save some coin
leaning towards the 2.5l 2wd mazda cx5 maxx... recon i can get that at 30... but the hyundai is a strong competitor
i dunno alot about the cx5 id have though the hyundai is a larger car and probably higher spec'd for the coin.
a bloke at work has the kia sorrento i think it is? all leather and shiz deisel paid about 40k brand new hard to argue the value 5 year warranty and road side assistance.. makes you wonder why we pay so much for euros.. that generally fark up.
side note.. housing bubble thread so silent these days.. this disappoints me.
Why are half their insides on the outside?
I wondered about that as well, and yeah think it just to make them look fancy and shit on the plate.
plus are a smallish burger so they gotta do something to make it look like more food
Forgave them after the taste tho.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
