Will be increasing boost, don't think stock 8 will be able to hold. 8MR bov was the other option but it's pretty similarly priced, so the TS should be good choice for me. Dual Port for options, but emo doesn't like atmo usually anyway iirc.
no car likes atmospheric BOV it's part of the reason cars don't have them from factory lol
I wouldn't recommend it...
When tuning you push the car hard to find its maximum, then you take out a little bit as a safety margin to accomodate for hot days, slightly different fuel, etc... If you tune on a crazy hot day then the maximum is going to be lower, and then you're never going to be sure just how much of a margin to take out... My last tune with Trent was fuarken hot, think it was a 40c day. His ventilation is pretty good, but it was sucking in the air from above his factory through the roof which was still pretty damn warm so the car was getting really hot and pinging off its tits.
If you can reschedule, I would... but who knows their schedule and when they can fit you in next.
Cheers man, sort of in line with my train of thought too. It isn't booked in firmly yet, so I think i'll leave it for the following week pending temp drop.
not sure about that, mine get faster laps when venting atm rather than reciric
you can feel the diffrenernce on lift off the revs drop much faster handy when braking.
That doesn't mean your car likes it, that just means you like what it does
the worst the car gets out of it is a little rich for a second.
and a few flames.
nothing I would classify as overly bad.
I run recirc on the street and vent on the track, it's tuned venting and seems to work.
Maybe on the track. I always found the surge annoying when you slowly decel.
yes well as said even just for convenience factor I ran it recirc on the street.
as when you lift off it does lose everything instantly, good for when I'm hitting brakes.
so decided too lazy to finish car for around the bay tomorrow rolling with comfy mazda3 style
Hey tard muffins,
I'm having my Annual Australia Day BBQ / Triple J Hottest 100 Party on the 26th (obviously)
All you regular wastelanders are invited (especially if you own a 34r and would like to come have a chat with Birds) to come and chill in the sunshine with a few beers and talk some shite :)
Let me know if you're interested and I'll add you to the facebook event.
Cheeeers
http://www.bom.gov.au/vic/forecasts/melbourne.shtml
Bout 40c for most of next week here too... What's it like there when it gets hot? Dry as all hell?
Yeah very dry and sunny. Then the thunderstorms and cyclones come through.
Had to shut last week because of cyclone. Lost power for a couple hours.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
