such troll, many anger :P nah but srs 8k rpm is nuts should be amazeballz shouild be a 10sec in that with the right setup of suspension / tyres / clutch (not that you care about the drags really)
Lee, just kicks in straight up and holds boost the same level throughout whole rev range basically
Edited by UNR33L
Yeah can't say I've ever been keen to enter a drag day
Happy to drag you down the Sandown front straight as some of the other boys do :P
I agree. Biggest rip. its for people who dont know how to change a flat, jump start or cant stsrt tge car when its flooded. Other than that, its a tow from regional areas.
Also, can use for other cars ONLY if you upgrade cover to a higher level. Which was quite pricey... I got missurs to upgrade for 1 month when we drove to NSW, then downgrade.
I had RACV roadside when I was 18 years old. Crashed a car, called up to get a tow. They said sorry can't tow you for accident, only if your car is broken down. I said I can't drive it, it's broken down, I need a tow. Sorry, not for accidents.
Canceled membership there on the spot. Useless dream boats.
I forgot about that, Birds. Also happened to me when I was 18.
jealous of Tony atm. my manifold hasnt arrived yet :mad:
car heading to workshop on wednesday for intercooler piping and other works. need to decide on BOV, catchcan and coolant reservoir. cbf. can forsee it now: ill buy something and it wont fit, or be too small or something much more suitable that i didnt know about etc.
Thats the problem with "generic" or misc. items. never sure how much effort you need to go to to fit stuff. and oil fittings... fark that shit. a world i dont want to get involved into.... stupid imperial and pipe measurements.
Tony could beat Leigh with some serious grip and a drag friendly suspension setup. Need MT streets or something.
Then again, hub dyno, Leigh might just get him even with traction.
Bed-Stuy, the place where my head rests
Fifty shot clip if a n***a wan' test
The rocket launcher, Biggie stomped ya
High as a motherf**kin helicopter
see you THOUGHT I was gonna do that
Leigh's car WISHES it was tuned on a hub dyno...
you wish your car was tuned on a hub dyno
hub dyno
Dyno dynamics is how we roll
not me... I prefer accuracy over wheelspin
of course in saying that my evo was tuned at chasers...
on a dyno dynamics...
and has no where enough power for wheel spin...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
