Give me 20 D Energizers.
20 C Energizers?
Not C, D.
C Energizers?
D, motherf**ker, D. Learn to speak English first, all right?
How many you say?
20, motherf**ker, 20.
Motherf**k you.
Motherf**k you? You, you all right, man.
Fkn who else lol
That might be true, on both counts, Adam, Ayayron.
Still haven't signed up, will see how the cookie crumbles.
Hmm should do a steps sesh soon... something always comes up when I plan to go haha
Edit; what is this walk to steps, bro? Run to steps :P. Deceptively far away.
