Teach her how to drive a man's car... like a manual micra
haha, she will have bambino in the car, so need something a little bigger! but i like your thinking! :woot:
if she could drive manual ive told her she can have the clubby..... shes thinking about it!
had my car over 2 years now, aus POS running fine with another 50% power than standard daily - love it
ITT: close minded import fanbois
grant I should aye :P
Edited by UNR33L
Do it!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
