awww yeah. got the card working. drivers werent installing so had to force windows to update the default motherboard gpu drivers with the AMD ones and presto. didnt think it was gonna work but bobs your uncle.
The oakwood stuff is reasonably good...and readily available at superepcobahn...comes with cleaner and a conditioner...smells like eucalyptus...or the meguirs stuff is good if you dont like eucalyptus smells...otherwise hit the waxit website there is heaps to choose from or places that sell quality leather furniture or even handbags often stock good stuff too...
  • Like 1
What do they cal bogans in Englands
we dont have bogans.
we have chavs.
this is a chav.
note the burberry cap. staple of the chav. also must wear a tracksuit, addidas or kappa. even tho they smoke more rollies than an entire prison.
either as above black rockport boots, or reebok classic trainers. lots of jewlery and a shit wet look hair cut.
usually ssen driving vauxhall nova's renault clios and all fords.
  • Like 1
wouldnt that be a hipster?
cant actually be a real bogan, but tries hard anyway? or wears the stuff ironically?
I don't think anyone would be a bogan ironically...
If you are not actually a bogan, you wouldn't lower yourself
give it time.
people thought that about people like me with tattoos, beards etc.
now every kunt trys hard.
Lol..Platts pretty much defines bogan hipster...I mean the beard, the iPhone...mixed with the tattoos The HSV and Peter Jackson's.. other than not wearing skinny leg jeans , You're all over it mate...kudos to you for at least trying to assimilate into our culture though...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
