wxactly what i was saying....
that mazda prob pays about 1500-2k aus insurance a year, expect that to treble next year.... hahahahahahaha
Is your insurance premium also based on previous accident costs as well? Didn't know that
So if I got into an accident with a ferrari tomorrow and was at fault, my premium would go up shit loads?
I know you premium goes up when you make at fault claims but didn't know it's also based on the $$ value of the claims
you declare you have a claim,
they will look at claim history, see it cost half a million quid and laugh at him...
i dont know if its tied together, but i should imagine his insurance will go up more substantially for writing a lambo of than say a mini...
No care if the lambo was speeding
Its as if the Mazda didn't look, and still kept going when the lambo was close
Mazda at fault
On a street lined with cars, the lambo is crazy low... If it was coming fast (it was) then even if that the mazda did look, but couldn't see any cars coming in the immediate area...
Lets say he could see 50m of clear space on the road he was turning onto, and couldn't see any other cars around because the lambo was low and far back, if the lambo was travelling at 50kph it would take a min of 4 seconds before it reached the mazda. In a 50 zone, that is more than enough to be considered a safe gap.
Also, with an accident like that you don't get airborne at only 50, or 80 ;)
Well it's definately a percentage game... My insurance jumped by $60 this year which was only 3%, acceptable. But if my mums insurance jumped by $60 then I'd be saying why the hell is is 15% more when the car is now worth less?
Called up Shannons yesterday actually to fix a few things on my policy... including my listed mods being Bilestine Suspension, Walpro Fuel Pump and a Power Sc...
Hey mang your starting to sound like the vicroads campaign ads
Called up Shannons yesterday actually to fix a few things on my policy... including my listed mods being Bilestine Suspension, Walpro Fuel Pump....
I called them up when referencing a quote and asked to alter some listed mods and they said they didnt care. ie if listed you have coilovers, they dont care if brand changes etc.
Did they mind about having bilsteins? (thought you always had them...)
Was more the typos that the guy made when I first listed off the mods, BILE STINE
Na, they don't care... I altered the Bilstein Shocks on the policy to now be Shockworks Coilovers, zero change to the premium, was just keeping the records up to date...
If you're on agreed value, once you hit a certain number of mods the car goes into the "Modified" bracket, and small changes/additions don't alter the premium or excess or anything.
also. my tempura skills has leveled up like x 100. who's in for nek dinner night?
Sounds good - I hunger some tempura
Yesterday I got rammed from behind by a guy in a Lancer, then we exchanged numbers :turned:
But on a serious note, he has no insurance and cannot speak very good English (been in the country only ten months). Luckily my insurance said they will wave my excess if I take down his details - also, since I'm not at fault, it will not affect my premium or rating :D
Still a pain in the arse having no car for a while.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
