Why are people such assholes when it comes to accidents and insurance? I've waited patiently for the other party to organise insurance and obtained a quote estimate for my car which they are saying is "too high" (why does that matter? The cost is going to be more than their excess so they'll have to pay insurance anyway) and they are checking with another panel beater.
Not once have I received a "sorry for damaging your car" since my car is in mint condition :( If I don't receive a response from them tomorrow then all hell is going to break loose.
never give a f**k about other people in insurance claims, worst thing you can do tbh
just get your insurance to chase them around for it and get what you can from the claim
Yeah, tomorrow is the absolute deadline to see what they will do. I only have 3rd party fire and theft, so they are hopeless when it comes to these things. He lives an hour away from me, so even if his "friend" panel beater (which I WON'T go to) gets a cheaper quote there is no way in hell I'm driving down there. It's inconvenient enough I won't have my car for a few weeks, which the panel beater near me offers a courtesy car as well.
If you got all the guys details and insurance company get one of those lawyers where you just fill in a one page form they do the rest costs you nothing they get payment from the insurance company I think
I did it twice was easy as
ppl asking about next monthly meet,
http://www.skylinesaustralia.com/forums/topic/441856-april-monthly-meet-tech-night-at-micolour/
monthly meet at micolour and given some suggestion what to look at when buying a car and spotting repairs.
we have some more fun events picked out for next couple months.
scumbag grad apps response boxes... mention no word-limits, then when i have written a felicitous response, it tells me there is a 400 word limit.
which of course, i had doubled +.
feck.
Hmm, which one did you go through? I have insurance and JustCar covers up to $3,000 for uninsured damage (assuming they don't want to go through insurance) which I "think" will cover me, hopefully I won't have to pay any excess for that and JustCar takes care of it (which is their job).
Also curious on this? Gf's bestie got hit by some fob woman and now her husband is refusing to make an insurance claim, this could help a lot.
I've had it when a motorbike ran into the evo, just contact your insurance company and tell them what happened they will pay you out and then chase up the person at fault (sort of like a debt agency) they have a certain amount they can give you, think justcar was $3500
meh I've done same.
some-one hits you
you can call your insurance company and they take care of it.
note you will have to your use their repair company not your choice.
but other than that so easy.
last 2 ppl that hit me, i've been with AAMI
I call them they get me to drop car next day
chauffeur car back to work.
car fin 4-5 working days later
chauffeur car picks me up from work
collect car.
happy
or if you not sure about crap drop it off at one of those sheen place that claim to take care of everything
plus give your a crappy getz to drive around
feck.
I feel ya, want a hug?
Apart from unigrad and gradconnection, you got any other sites?
meh I've done same.
some-one hits you
collect car.
happy
Is this with Third Party though Martin?
meh I've done same.
some-one hits you
If you're not at fault you're allowed to choose your own repair company (spoke to the panel beaters who told me the situation). It's an inconvenience for me having to get my car repaired, so no way am I going to one outside my suburb.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
