because dba and bosch are giads when you can pay the same for decent aftermarket gear :)
but he has DBA already...and what you call "decent aftermarket gear" often isn't any better than the DBA or Bosch gear it is just directed at more niche markets...
you get what you pay for, doesn't matter which company you get it from, price usually defines quality..so you wont necessarily get a better product but you may get one more suited to your needs...
wut????????
just stop dave. your emabarasing yourself, me and everyone else here.
have you had you pill today?!
well go and put your pants on and take it.
and forgod sake get back in the house and stop shouting at those kids outside.
anyway just defending my Bosch quickstop brake pads...they are really good, quiet, dustless and quik to stop
DBA discs have been known to fail on racecars, but thats because they are cheap....you get what you pay for...
unless you are English, then apparently you get everything amazing at bargain basement prices...lol
and dont worry dave your butt hurt about my wrecker car costing less to get on the road than your free one will soon be over, im spending a lot of cash at scottys!
I dotn know where you ever got the idea I am butthurt...My cressida is 11ty billion times better than your micra...
hahahah cause it is.
cos its yours.
mike i totalled it up the other week but just to go from wreckers to road, its under 2k. with mods and turbo kit, under 4. when its finsihed.
i could have bought wrx for 5, but this is more fun.
my cressida was on the road well under 2k...
300 to pick up car
200 new windscreen
175 new ball joints
40 bonnet struts
125 rwc ticket
75 for temp rego
900 plates and rego
25$ oil change
so
$1840 give or take a few bucks
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
