f**k that,
having a break tomorrow...
had to go to a vcat hearing a couple days ago lol.
customer had bought a fridge from us 6 or 7 years ago.
fridge didnt work, issued 3 warranty call outs, in the end we agreed on a refund.
dude rocks up with a munted fridge, claims it fell off the truck but its still our fault that it fell off the truck.
then trys to get the full refund out of me,
in the end i offered him 1300 which he declined, kept it for 2 years and had to scrap it.
then takes me to vcat for $2700
ended up settling on me paying him $850 lol
mate was interested in it if it was cheap enough
she wants $12k with no rwc, no rego, car looks like balls, and a wrecker engine, dreaming
Offer her $50 and a crack pipe then?
As long as the compression is good that would be a decent deal I would have thought
Car looks like shit still compared to when I had it, also going by what her previous car looked like it's no surprises it looks like shit
I like dimple 15 but for the same money I prefer Glenlivet 12
if you want to start, minimum spend on a drinkable whiskey is ~$50
for a beginners scotch @ $50 you can usually get glenlivet 12, glenfiddich 12, dimple 15, balantynes 12, or chivas regal 12 - any of these are very approachable drams
If you are happy to spend the coin I would say the best one to start on would be Glenmorangie 10 year which will run you about $65
best value would be JW black for $38 @ dan's but this is a) not as nice as the above b) much peatier, which is not as beginner friend
Thanks, will probably give the Glenmorangie a try. Best way of drinking it? On the rocks?
Mad they've got more money than most of the people in there...
Incorrect.
They EARN more money than most people in there, then spend it on a maloo, a jetski, a dirt bike, piss and hookers and then leave the mines with nothing to show for their wasted years :P
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
