is checking fuel pressure the best way to test if a walborough pump is working properly? or just safer to replace the whole thing?
Also chatting to previous owner last night (who is cautious, but also talks some absolute shit) and raised concerns about E85 on old fuel lines and seal (I have seen a document warning cars pre-2004 to steer clear of any ethanol blend because it eat through certian rubbers over time). He also mentioned E85 water/fuel separation if left stagnant in the tank for long periods of time... comments?
Please E85 propaganda experts, you're my only hope.
Fuel pressure combined with flow rate...
You can have a pump which can build up to 45psi over 2 seconds, and then a bung pump which can build up to 45psi over 10 seconds due to low flow rate... Only one of these is going to be able to keep up under high boost situations, do SR20's have a rising rate FPR?
We even for last night lol. But know you owe me twenty for actuator. But I owe you for muffler.
Where does it end!
Huh?
Why do I owe you for the actuator again?
I work on car for free then? Oh okay.
Hey everybody free repairs farken.
Im joking. I got one jd
This is not enough to cover an angry ass pregnant wife that thinks I'm having an a fair with scotty.
LOL @ an affair.
In that case... A slab of ze german beer.
Most of those documents regarding ethanol and old fuel lines are propaganda written by companies with a vested interested in keeping motorists using normal petrols or distributors being overly safe for liability reasons...
And we may spout pro-E85 propaganda, and then it becomes he says she says...
But the difference is, that the pro-E85 people actually have thousands of running vehicles from the early 90s to prove it's not an issue. Now show me all those explosions and fires and clapped out fuel systems from using E85 on pre-2004 vehicles :rofl:
E85 for 6 months and counting!
St Johns First Aid training course tomorrow
Sitting in a classroom with a bunch of other idiots all day... meh, still better than work.
Just remembered I need to memorise a 47 page pdf of pre-reading info before I get there, blergh.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
