hatch the thing handled like ti was on rails previous owner had set up the suspension rather nicely.
the 2.4 3V engine had plenty of torque but not enough power.
a nice engine swap and would have been such a fun track car.
a good mate of mine bought a camira with rego and rwc for 1500 bux and it literally is the best car ever.
ac is like a blizzard, heater is like hell.
hes the 2nd owner too lol
is amazing how well a properly serviced car can hold up hey ;)
My Cressida is like that, one owner and everything works like new, except AC which probably just needs a regas...
Old school track Celica's aye
Should be seeing this one at the tracks soon
Stripped, built motor with a big external high mount Garrett 3582 and lots of other funky stuff
Dat camber :woot:
tis a beasty for sure, hes good with a Toyota M engine too :P ....
wish he'd put some supra flares on it though
works on the theory all the crap ones died years ago..the survivors were the few good ones
