Pics of black VE SS utes with decent rims.... considering getting aftermarket rims, or just powder coating the stock 19's black to change it up when I get new treads...
No bigger than 19's though, still need to tow the bike etc with it ..
tell me about it, every time I fly out thow out a fridge full of stuff.
such a waste
or end up eating out instead of buying stuff in also wasting money
I feel your pain brother.
All dat wastage.
Coles offered 2 for 1 pack of cherry tomatoes!! I didn't even get a chance to open the second pack before turfing it.
Damn you society for making everything family size/deals
so I google varreston commodore as there a set I saw on a VE a whiel I actually liked
and what do I get returned
haha
and yeah pretty sure the above same as mine I had 20s on some concave style but back to 19s with phat tyres <3
Edited by UNR33L
This is mad:
10454079_531686560288091_283796237126407
Heres the link anyway to fb group I have liked have a look:
https://www.facebook.com/SlammedHsvsFpvs
it's easy, just find good jap style rims in good offset - throw on holden / ford - then look better than 99.9% of other ones out there
Edited by UNR33L
artworks-000042030583-sysjkt-crop.jpg?30
Yeah, but you think D1R's or whatever they're called, look good..
This is mad:
Yours are 19" in that photo? they look smaller... Would probably look even smaller on my car with the bigger guards...
No point getting ideas off the ones you posted above when they've got massive flared/bolt on guards and slammed within 20mm of the ground.....Won't look anything like that on mine..
Yeh mine are 19s in that pic, the reason they look smaller is because I went up a level of side profile in the tyres for more grip as well.
Prob with 20s as well is makes brakes look tiny.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
