inb4 3 way rolling drag between leigh, turbo dragon and myself
We're all RWD yeah? We can do standing start, but not much forward movement will be happening for the first 3-5 seconds for anyone though. Will be a great smokeshow though :cheers:
Shitty suspension and stock diff I wont be going anywhere till 2nd-3rd gear
Pretty sure Leigh's supercharged auto will demolish me from a standing start
Yay! I've decided to supercharge the 6L and car is booked in for the 30th to get the charger fitted and tuned :woot:
Decided to go for one of these bad boys, mainly because it looks stock-ish:
http://4.bp.blogspot.com/-NS_WDLsBZq0/T1_LQpRAIiI/AAAAAAAAAqk/OsyXOdfz1uY/s1600/stealthforce.jpg
Looks pretty inconspicuous despite the badging. How much power you expecting? Who is doing the tune?
Shitty skyline suspension > "above average" commodore/falcon suspension ;)
Yah, liking it cos there's no massive supercharger belt out front and almost everything is hidden under covers. Might have to find a way to cover up the badging, like vinyl wrap it or something haha Has 12" long inlet runners so apparently the torque gains are massive when compared to Magnuson and Whipple chargers.
MPW will be doing the work and specialise in boosting 8's. They installed and tuned the cam for me and I ahve been stoked with their service and attention to detail so far, so was a no brainer to hit them up again when I decided to go forced induction.
With the smaller pulley (10psi) and current combo, on 98 the tuner is confident for high 300s at the wheels. On E85, well over 400rwkw :)
vwlbc drags night on private track
AKA dandy factories
considering my ute is tail happy with maybe 130ish...I'ld hate to drive it!
admittedly holden don't have cart springs for rear suspension, but then they don't tow/hold as much.
now that in a sports wagon would be fun.
Yeah my car definitely be better off the line than on roll, the more gears I go through the better - dat auto gearbox ftw.
Or take your cars to the drags and try to better my current best of 11.61 :D
Do they still want $10k for that kit?
Did it come with any supporting mods? Injectors/fuel pump etc?
Seems a bit pricey for labour and essentially bolt-on parts.
Should just buy a couple of sss pulsars amiright?
  • Like 3
lol, nah im serious. i wasnt the only one who thought it was pricey, especially considering they quoted turbo conversion for the same price.
Yeah but think about the type of bloke who supercharges his commodore... they're probably almost all FIFO workers
  • Like 2
I have 4 mates with blown 8's (not inc sau peeps)
2 FIFO and 2 local tradies
Both FIFO workers lol
  • Like 1
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
