inb4 3 way rolling drag between leigh, turbo dragon and myself
We're all RWD yeah? We can do standing start, but not much forward movement will be happening for the first 3-5 seconds for anyone though. Will be a great smokeshow though :cheers:
Shitty suspension and stock diff I wont be going anywhere till 2nd-3rd gear
Pretty sure Leigh's supercharged auto will demolish me from a standing start
Yay! I've decided to supercharge the 6L and car is booked in for the 30th to get the charger fitted and tuned :woot:
Decided to go for one of these bad boys, mainly because it looks stock-ish:
http://4.bp.blogspot.com/-NS_WDLsBZq0/T1_LQpRAIiI/AAAAAAAAAqk/OsyXOdfz1uY/s1600/stealthforce.jpg
Looks pretty inconspicuous despite the badging. How much power you expecting? Who is doing the tune?
Shitty skyline suspension > "above average" commodore/falcon suspension ;)
Yah, liking it cos there's no massive supercharger belt out front and almost everything is hidden under covers. Might have to find a way to cover up the badging, like vinyl wrap it or something haha Has 12" long inlet runners so apparently the torque gains are massive when compared to Magnuson and Whipple chargers.
MPW will be doing the work and specialise in boosting 8's. They installed and tuned the cam for me and I ahve been stoked with their service and attention to detail so far, so was a no brainer to hit them up again when I decided to go forced induction.
With the smaller pulley (10psi) and current combo, on 98 the tuner is confident for high 300s at the wheels. On E85, well over 400rwkw :)
vwlbc drags night on private track
AKA dandy factories
considering my ute is tail happy with maybe 130ish...I'ld hate to drive it!
admittedly holden don't have cart springs for rear suspension, but then they don't tow/hold as much.
now that in a sports wagon would be fun.
Yeah my car definitely be better off the line than on roll, the more gears I go through the better - dat auto gearbox ftw.
Or take your cars to the drags and try to better my current best of 11.61 :D
Do they still want $10k for that kit?
Did it come with any supporting mods? Injectors/fuel pump etc?
Seems a bit pricey for labour and essentially bolt-on parts.
Should just buy a couple of sss pulsars amiright?
  • Like 3
lol, nah im serious. i wasnt the only one who thought it was pricey, especially considering they quoted turbo conversion for the same price.
Yeah but think about the type of bloke who supercharges his commodore... they're probably almost all FIFO workers
  • Like 2
I have 4 mates with blown 8's (not inc sau peeps)
2 FIFO and 2 local tradies
Both FIFO workers lol
  • Like 1
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
