but gtst are cast alloy are they not?
strong misinformation you share. Make stupid people you will..
Shhh :P
best I can do is in my build thread. just one pick.
was hoping for 1 photo from winton, but you know how it is: pulsar lucky to get one photo from a whole day of driving let alone out for 2 sessions.
Paint gayside blue, put GTR badges on and some not so clever custom plates. You'll have full blog posts of the same angles over and over :P
  • Like 1
Sif no 20's, I have an angle grinder here...
darren is serious about that micra mate, hes just joined the site and asked the flamin mongrel to drop his price.
this is the dick that was questioning the power
Reduce your taxable income by $100 = hardly worth the time it takes to enter it lol. Hope you kept your chair receipt too, haha.
E-tax is shitting me up the wall. Won't lodge return cause can't match MyGov account, WTF
Also NIB gave me 40% government rebate instead of 30%, f**ktards, so now have to pay $155 back...which I can't eliminate with deductions because as I add/increase them, my offsets get reduced.
Oh well, all tax back minus $155 is pretty good. Now if I can just lodge the fker :/
haha yeh not just that but every little thing counts
didn't get as much back as last year myself but can't complain with a couple of k :D
you should of gotten a fair bit back yeh cos you weren't working a few months? that's what happened to me last year
Edited by UNR33L
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
