$600 fair price for HKS super dragger to suit evo 8 ?
I've seen Apexi N1s go for like $250 in gc
However I've got a really good mate that does exhausts that would be able to build you a killer one for cheap, flow well and sound good to
He is is Roxy too
its the factory FQ exhaust (hks superdragger) as the car has an nvidia on it
so the hks one is just sitting in the garage, thinking of selling to free up space as im not using it
maybe ill do like $200 on ebay and let it go for whatever it sells for
Do that....
Martin travelled a lot
Mohsen finished his car.... It broke... He fixed it... It broke again... He fixed it... It got backed into... He fixed it... It caught fire... He fixed it.
He then bought a jetski in the middle of winter and is now trying unsuccessfully to sell it.
I am having a second child
Alex bought an a5, discovered all euro cars suck as sold it to buy a Nissan SUV
Paul bought an FQ340 but never drove it because he was too busy f**king with the ECU
Alvin got keyed again, he then got defected for his spoiler stays being too pointy and was fair butthurt.
Birds was just birds, but he started banging leesh. He is still birds.
Nick bought a crown and is VIP stylin
Artz bought 2 cressidas and is putting a 1j in one of them
Scotty fabbed things for people.
Ay-ay-Ron sold his s14, it was then destroyed by some doichebag
I sold my 33, it was also destroyed by some doichebag
Ric stared work at the ATO
Tony's car was stolen and destroyed.
He bought back the wreck and turned it into a ducking monster
R34 GTR meets need security now
Grant bought and sold a bunch of cars including a GTR that he had previously owned then had a sook about life
  • Like 1
Dezz got more into bikes and started racing them... He is still alive, and more tattooed
DR Drez became Our first billionaire
VWLYMCMB was formed
Pat f**ked off to WA for some mining job and got 7 final inspection details
  • Like 2
VWLYMCMB was formed
Jonoe became a Honda fag
Haha wow thanks for the great re-cap and congrats on the new kid on the way :)
Ive seen Mohsen's non stop trouble with that thing. glad to hear everyone is all good then. What's with needing security for R34gtr's? are they being stolen more often now?
No one cares but my re-cap is as follows:
-BMW M3 was the biggest money pit known to mankind
-Im now driving a C43 AMG ( pics soon) and its built like a tank.
-finished my diploma in project management
- went through a very rough patch but im on the other side of it now and back on here (obviously).
- plus im an Uncle now :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
