1) buy pulsar/micra
2) sell skyline
3) profit
Don't you mean:
1) buy pulsar/micra
2) sell skyline
3) buy handbag and bra
4) wear bra and carry belongings in handbag
3) poo sex with other guys
Edited by T.D
  • Like 2
Don't you mean:
1) buy pulsar/micra
2) sell skyline
Pretty reasonable.
he knows.
fwd turbo all day.,
He knows? Maybe he does........ refer to below:
Don't you mean:
1) buy pulsar/micra
2) sell skyline
thats a bit harsh. yours is nice...
hahaha haven't seen that one before, but might have to destroy this page before any Ford people see it.......
Oh yeah? Well, Micra stands for.... Maybe I Can Rape Apes. f**k you.
:P :P
:P :P
I see Ford salesman lurking right now :P
Figured out what im doing with my tax return...
Sportsbet has a bet for the 2nd coming of jesus. He has to return by 28/08/15 and has to be proven to be jesus. Pays $501 dollars. Decent payout
Hahahaha ok, you win :cheers:
What?!?!
lol so if you throw down $50, and Jesus rocks up within a year and says "Sup, I'm jesus" and it's proven not to just be a homeless guy on meth... You get $25k in the bank?
You can be the Jesus.
All you need is some plants, bed sheets, some wood and some nails.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
