bullshit flamin mongrel if i died hamish and dez would be out in the streets setting off fireworks and shooting ak's into the air.
Will they?
I don't think so, since both Hamish and Dezz are norfside enough to do that.
that's just for the drive there right?
remember one of my mates turning up to winton in his R32 GTR
factory seats and everything, but arrived with full harness on and race gloves on..
3 years later and still not lived it down.
I don't really see the problem.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
