standard 33 GTR seat failure.
came into a left 270 and as I smashed it into 1st and ripped the handbrake the seatback let go and I ended up in the back
LOL!
that happened in a VL i was driving. didnt rip the handbrake, just turned a corner and planted it
the worst by far was that one when it BUCKETED down and that guy was there in the elfin clubman v8...
Poor dude had the worst day... freezing in the morning with no roof (he wore his helmet on the drive up) and then flooded on the way home (was using said helmet to pail water out whilst driving)
I was running 235 NT05's and driving at ~80 tops on the fwy as the car would just aquaplane into other lanes randomly...
yeah after sau nats in shep (the best one, when i finally met the one they call dezz, and jonoe and i realised that birds sleeps like hes dead)
driving back home with -6deg camber was sketchy as f**k.
had a mate who knows what hes doing when it comes to wiring come and help tuck the headlight wires, relocate the front body harness.
f**k me.
nissan really couldnt be f**ked with these cars..
that was the guy that was on R888 semi's and found out there was no drain plug in the car...apparently drilled one when he got home.
think i recall driving behind you and seeing your car all over the place
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
