Jack from Citywide towing on 0419877437
towed most of the SAu motorsport ppl at some point, plus grant a couple times.
used to do a bunch of track days in his 33 gtr so he know how to get them on and off the tray.
only issue is when he tries to buy the car off you, eh grant....
Well, he didn't talk me into selling it to him.
I offered it to him and agreement was done that day.
i know, he doesnt even have a second job or a kid.
lol
I do drive to Norfside everyday and that's not even far.
Try living in Frangers and work in Williamstown and tell me that it isn't that far.
Do this 1000%. Get out of the northern suburbs
This.
Living in the norfside is bad for you.
Can't f**king believe I lived in Epping for 12 months... And still can't f**king believe the R wasn't stolen for whole time I had it while living up there.
No just get out there and try some new shit, new hobbies etc.
This, avoid expensive hobbies.
Before you ask, I haven't able to find cheap hobbies I like doing...
lol
how about live Williamson, and work, pretty well anywhere else in the world....
where did you work in willy?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
