Interesting that the boost ramps up slightly slower with E85 despite making more power at that stage anyway.
40rwkw gain in the mid and top out of 1psi, that's a nice chunk of power.
Yeah quite good considering I'm seeing people only make 300kw with -5s and E85 on the RB26 Result thread, with similar boost. You'd expect a lot higher with bigger turbos!
Keep in mind when we did the 98 run it had stock injectors in, E85 tune it had 1100cc Bosch injectors, some new style that have a GTR plug :)
Thats probably either people being conservative with boost or old results?
how many times have you heard
how to get away with murder
im so confident i could wet myself
the block triple threat
so over these SHIT ad's with extra high freq and sound modification to make them sound louder
cannot wait for my auto volume control box
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
