Oh sorry... I should have been more clear and less "amateur"...
If you want a red nike air max 90 and aren't a complete sucker, you can get them from Nike id in your choice of 2 ever so slightly different reds than the ones dezz paid a kings ransom for, however you won't be able to say they are the "independence day pack" on sneaker-loser-douchelord forums.
Better?
Better?
Imitation is the highest form of flattery. The 'ever so slightly different reds' are not even close to the same either.
And they'll always know they couldn't afford the real thing :)
You keep telling yourself that Bill Gates...
We are talking a couple of hundred bucks here, more likely those people just have more sense than to spend that on sneakers...
When you've got plenty of disposable income, you really don't give a f**k what things cost or what people who can't afford it think of you buying them
And they're more than a couple of hundred bucks :)
If that was the case you wouldn't have put them on facebook banging on about how exclusove they are ;)
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
